1 - 2 of 2 Posts
I have a LS6 Im trying to restore. The carb is a 780 Holley. I noticed that when I bolt the carb down to the top of the plate Im hitting the accelarator pump lever in the front.This cant be normal!!! It looks as though I may need a bit more spacing under the carb. Would anyone have any suggestions. The heat sheild came with a small paper thin gasket between the carb and the sheild and a much thicker gasket between the sheild and manifold.
jim
jim
The heat shield you are trying to put on is not original equipment. It is a counter part. I have run these before and you need a thicker base gasket to make it work or flip the gaskets around (put the thicker one on top thin on bottom). They look kind of neat on there though.
Micky Hale Restorations
69 L-89 Chevelle
68 Biscayne 427/425
34 Plymouth Drag Car
ACES #134
www.mickyhale.com
[This message has been edited by micky69396 (edited 07-16-2001).]
1 - 2 of 2 Posts
