Hi Guys,
I am very interested in doing the LS1 swap on my car. I have the calipers, rotors, bracket for the rear and stainless steel russel brake lines from a 2001 trans am (so there 12 rotors in front). I know the sell the brackets for the C5 conversion up front, but do they sell one for the 98+ conversion so I can run 16 inch rims? I do not really feel like putting 17 up front. (If possible for the factory disc spindle, or does this only work with drum spindles?)
Thanks any help is appreciated.
(If this helps, I just ordered a complete BMR suspension with the extreme bar in the back, planning on QA1 coil overs in front and koni adjustable in the back, I will also run a LS1 rack and pinion(self design in process))
