121 - 140 of 153 Posts
I found it, they look pretty good Looks like close to $1990
I assume that's for the full kit. Since you already have the ECM you could save some $ by just buying the harness and having your ECM flashed. I assume you have most of the sensors so you'd just need the corvette gas pedal.
For example here's the gas pedal for $87
Here's another source for you to explore. I bought my stand alone module/fuse box from them & it made my wiring conversion much easier. They also sell full harnesses & offer ecm programming.
It's $1845, $995 Harness
$400 Programing
$450 cruise
The cruise control is going to be an add on no matter who you go with. I believe they're using the Dakota Digital which I believe is a Rostra unit. Dakota digital sells it for $440
An interesting thing I found was the E67 ECM used in the Trailblazer SS has a cruise function activated in the ECM so it only takes the proper switches to make it work. I saw some site that boasted that they were one of the only companies that had cruise control with the E67 but for the life of me I can't find the vendor again.
I'm not sure about the cruise, I would like to know if I don't get it now would it be an easy addon or do I need to get the ecm reprogramed?
You need the cruise module that came with the Corvette & then you need to figure out what you're going to do for a switch. I wound up using a column from a 95 Buick Roadmaster with the factory turn signal switch that has the cruise control integrated into it. Tried to use the 2000 Camaro column first, but it was too wide for the dash opening of a '67.
Discussion Starter · #133 ·
That seems like a lot of hassle at this point. I have so many other things to do.
Nobody said this was "easy", but honestly it sounds more overwhelming than it really is. It's just time consuming & requires a lot of patience.
I can't d/l. I get message that says it can't be d/l securely
PM me your email...I'll send it. I dunno how you Windows guys function with those antiquated things fradulently labeled as computers.
