I going the same way that Philip and Mike did with an in-tank pump. Doing a 6.0/4L80e swap in my 72. I did install the "sock" prior to installing the pump assembly in my tank. Using Bosch pump 69225.
It’s a Holly pump. I mounted it with the isolation clamps which is important.Dennis, what brand of in line pump are you using? Inline pump would be less trouble than a in tank pump. If it isn't really noisy. I don't like noisy pumps.
Eric
THe wagon tanks are a lot different than the car tanks.Hey George, because the fuel pump or it's pickup needs to be immersed in fuel all the time, I usually recommend something like the Aeromotive Phantom setup that places a foam bucket around the pump in the tank.
Here's what I ended up doing. It's a stock non-return ZL1 pump good to 900hp and a VaporWorx controller powers it. Red circle is a Tanks Inc. tank vent I hosed to a charcoal filter up behind the bumper.
Philip,The shape of the tank makes most of the aftermarket pump systems unusable for a wagon tank. The good thing the shape of the tank works well without the need of sump in the tank.
Here is a stock fuel pick up next to the modified one with a pump. The tube was bent to allow the pump to set vertical in the tank with the strainer on the bottom.
I have a spare tank and sender. AFAIK wagon tanks and sending units are not reproduced.Philip,
the modified one, did you buy a replacement sender unit and modify it? Or did you have a spare original unit?
