What's everyone running for cooling systems on your LS conversions...???
I don't have a decent radiator for my 72 wagon/5.3L LS transplant.
I'm leaning towards springing for an aluminum rad and electric fan setup. I've read the "Electric fans/aluminum radiators/real lowdown" in the Heating and Cooling section...(that kinda' turned into a whizzing contest about options)...I want to hear from you actual LS users on what your cooling needs are, and how they were met.
I don't have the original fan off my 5.3...it, the radiator, and the shroud were missing. (I used the original setup from my 2000 6.0L into my 1986 C-30 swap and it cools great).
Hence my asking about what options you are running.
I went balls deep in the LS platform for myself two years ago and they are definately a different way of making a pile of power for a whole lot less money than a SBC/BBC.
The strangest thing is temerature. My busted 6.0 and my 402 stroker both lost et and mph at cooler temps. From a cool down spell at the track because a Ford or Hinda couldn't contain itself to the odd times I trailered the car out.
Under 180 degrees the 6.0 bested 11.65 @ 117. At 230 degrees (put a 190 stat in) it consistently ran
[email protected] 120. I killed it with kindness and nitrous oxide so I bailed and bought a buds bailed on 402 stroker shortblock for $3k and dang if it didn't run
[email protected] 123 at 180 degrees versus
[email protected] 128 at 220 degrees.
I ran no stats in both motors and couln't get temp, and you can see by my sig I like my BBCs. And with a BBC, at least in the last 20 years, the cooler you get them to run, the more balls they make. The LS platform seems to love an uncomfortable temp. I finally settled on a Delco 195 stat and I always shut the fans off before the burnout to get a few more degrees out.
Another silly observation. My big Block herd as a collective seems to gain 20-30 degrees during a pass, a few more if I am spraying it. The LS seem to wall around 235 if I can get it, but it never seems to go higher during a pass. If I am running cool and make a pass, I might get a 5 degree increase during a burnout, a nitrous pass, and the return road, although I lose a few tenths on my ET.
Something about the LS platform and super thick cylinder walls, combustion chambers and the camshafts I run seem to love coolant temps.
My cooling system on the car I am talking about, an alligator skinned interior 78 Malibu, is an eBay Champion 3 core (row), twin 2000 Camaro fans, wired to twin toggled Bosch relays with a single grounding at 240 degree grounding switch in the rear of the RH cylinder head.
My other Malibu, a 505 stroker powered is a different system all together. A Champion 3 core (row) with twim 14" Spal fans, a 16 pusher up front, all wired to toggles and relays. Couple that to no stat and a CVR electric water pump, all you do is shut the car off, turn on the cooling statem and in five minutes, you dsrop core temp by 50 degrees.
