The topic of “what pan do I buy” has come up many times. While there are plenty of options out there, few actually fit the A-body. I would like this thread to be about ACTUAL fitment and questions related to those who have spent the time to test fit. The pan is only part of the equation. To correctly identify fitment, adaptor plates, engine (motor) mounts and frame mounts must also be given.
The other side of this is doing something that you will regret later and that’s changing the driveline angles. In this case, the easy fix to get some of these pans to fit is to just raise the engine up. While that will normally correct your pan/crossmember/tie rod end clearance problem, you’re creating a huge mess for the alignment of the trans/driveshaft/differential. I would never recommend altering the engine placement as a temporary fix. I would never build a car like this and I won’t here either. All the mounts are at their factory location or where the parts place them. No spacers or other mods (frame notching) are acceptable for my build.
I’ll start. Here is what I have found for the 66-67 Chevelle/El Camino;
Here is the mounting information;
Dirty Dingo Sliders (LS adaptor plates) part # DD-SLIDER
Energy Suspension LS conversion kit 3.1148 (this was the first kit I used until I switched to the DD sliders)
Energy Suspension engine/motor mounts part number 3.1114
Factory small block Chevy frame mounts GM part number ?
I have three pans that I tried in my 67 El Camino and my 67 Chevelle. Also, for MAXIMUM clearance, the sliders are all the way back towards the firewall. This helps the sump to crossmember clearance.
Factory truck pan from 2002 Silverado 6.0L
2008-2015 Cadillac CTS-V pan GM 12065818
Canton Racing Products road race baffled pan 15-274
Here are all three pans together for a visual comparison. Picture 1 has the pans labeled so you can follow them in the following pictures. The truck pan has some significant differences in dimension as compared to the CTS-V and the Canton pan. The CTS-V and Canton pans have some similarities and some glaring differences that will become evident in the fitment pictures. (Pictures 1-6)
