Hello!
I will lower my 67 SS a bit, and go the professional way not to cut the springs. You can´t cut the rear pigtail end, also i bought a set of global west lowering springs- 1 1/4" drop in the rear and 1" in the front.
I installed the rear springs today, but now the rear of the car was higher than before! I don´t think the new springs will settle down, so i removed them and had an idea:
I disassembled the spring mounting bracked at the rearend. It simply consists of a piece of pipe and some washers, hold together by a long screw and nut. I will cut this pipe 1" or 1 1/2", so the spring seat and so the car will come lower the same number of inches. And the spring will be in place at max spring deflection, too. I marked the piece of pipe in the pic.
Anybody did the same way? Any doubts?
Thank you!
Thank you!
