measure from the center of each wheel opening edge to the floor/ground to have a starting point.
i have bmr2"lowering springs on the rear of mine currently, changed from some progressive springs used on a olds-cutlass.
running moroso trick springs on the front
front tires are 215/65x15, rear are 275/60x15 car looks low and sits level/flat
your front/rear tire size[diameter] will make a difference in ride height also...
Shane,
We offer 1" & 2" lowering springs designed with a 2-door coupe/SBC in mind. Many customers call and ask for specific ground-to-fender measurements in mind.
Unfortunately, we cannot 100% predict a fender-to-ground or more impossible tire-to-fender measurement because there are literally dozens of different results for any given spring on a GM-A body. The reason why is due these variables:
· Make: Chevy, B.O.P. (wheel-well shapes vary)
· Body Type: Coupe, Sedan, Wagon, Utility Truck
· Engine: 6 cylinder, V8 in various GM brands
· Options: AC, Power Steering, Power Brakes
· Spindles: Stock spindles or drop spindles
· Wheel/Tire sizes: 14"-20" & the corresponding aspect ratios
· Body Bushings: If the body mount bushing are old (compressed) or new
All of these variables will actually determine the eventual ride height of a GM A-Body. I hate to tell customers that it is a guessing game, but with all of the variables mentioned it can be.
I always suggest to guy that are after a very specific stance to go with Viking or QA1 coilovers. Not only can you dial in your ride height(stance), you can dial in the shock for what it is that you are doing with the car that day, that weekend or for good.
