Am doing front sys on my 69. I pulled the control arms, cut the rivets and removed the upper ball joints but I don't know how to remove the lover ball joints, Do they press off??? Any help would be great.
Thanks.
p.s. I did a search and the chiltons is not much help.
The lower joints are pressed in. Find someone with a press and have them removed. If you are brave, a hammer and drift will remove them. Be careful not to damage the a-arms!
Hodge is right. You can do it yourself, but becareful. You really need a press. Several years ago I bought one of those cheapie 20ton presses for about $200. Never knew how many things a press is good for. Excellent investment.
My experience is that some fit VERY tight and must be pressed, while some are not as tight and can be "hammered" out.
I bought a $99 - 12 ton press and also find it extremely useful!
