One of the lower ball joints on the '65 has dropped out of the control arm. I had the suspension apart working on the springs and shocks. I took the castle nut off to lift the drum off the ball joint and the joint dropped out of the a arm. Hmm...that doesn't seem right. Right?
I need a little guidance here. I haven't replaced ball joints before. The new ball joint comes with the joint and the boot. Does that ball joint get pressed right into the hole in the control arm (I know it gets pressed in...I borrowed a press) or is there supposed to be some kind of bushing in the control arm? I ask because I can slide the new ball joint into the hole and put a little hand pressure on it and it fully seats. The press won't get it to "stay."
I'm missing something here. The directions say slide the ball joint up into the hole, use the press to seat it, then slip the boot over the stud.
Thanks guys!
Thanks guys!
