1 - 20 of 97 Posts
Just thought I’d share some of my experiences and pics all in one place with part numbers and a little how to……. I’d also like to thank everyone here that helped me along the way.
Before: 3 hole top plate, 21 inch wide copper core radiator.. with electric fans taken from an LT1 Camaro. Temps exceeded 220 often.
After: 4 hole top plate, 29 inch wide Aluminum radiator and the things below…. I couldn’t get it to 190 no matter how hard I flogged it, 102 outside temp.
Parts list:
• 4 Hole chrome top plate Ebay = 20.00
• 19 inch XT1 -7 blade fan - U pull it = 10.00
• Hayden 2747 HD clutch = 49.99
• Murray 433322 -29 in wide, 18 inch tall Aluminum radiator (specs on their website are jacked up, trust me it drops right in) I paid = 140.00, Listed at 159.00 right now.
• Shroud 1971 BB (one piece) from Summit OPG-00T218R = 59.95
• Upper hose Gates 21204 15.00
• Lower hose 21324 lower 12.00
Total 307.00, rounding up.
I gained a brand new free flowing aluminum radiator with 8 extra inches in overall width and a car that I can’t get to run over 190 with it being 102 outside.
There are actually 4 perch spots on the core support for different configurations. 29 inches being the widest.....
Then I welded the 3 holes shut on the top of the support and welded in 4 new mounting points for the MUCH wider 4 hole top plate.
Then I cut over 5 inchs out of the driver side of the core support...
Discussion Starter · #2 · (Edited)
CONTINUED:
The rest dropped right in :)
Hey nice work Darren! Thanks for the pics & info, I'm gonna be going through the same process later this year going from a small to big block. Trying to decide if I want the front runner system and then finding a reverse 7 blade clutch fan. Putting a lot of thought into all that SWHEATON has been posting in the cooling issue threads.
Discussion Starter · #4 · (Edited)
Thanks Skip, if you are going from a 3 to 4 hole top plate please take note that it’s NOT centered on the core support. . It’s actually off to the driver side about 2 inches. I would suggest re-positioning the lower rubber perches, setting the new radiator in place and positioning the top plate on the new radiator to make the marks for your 4 new holes.
EDIT: and Scott is really passionate about cooling and from what I can tell a cool guy….. the stuff works!
GREAT NEWS!
I told you the clutch fan setup with hd fan clutch ,160 stat,proper shroud & proper type clutch fan would do the trick.
I bet you would have got almost as good a result with the old rad but new rad is definitely good too esp since you don't have much invested for great cooling like I tell everyone that setup gives you.
The lrg 7 blade clutch fan,new hd thermal fan clutch,proper shroud and new rad are what collectively reduced your temps from 220ish to max of 190 which is great .
You didn't list the stat your running,i bet its a 180 stat since it maxes out at 190 deg ,180 stat try autozones 15356/160 hi flow stat because I bet it will reduce your current 190 max temp to 180 ish which is what happens every time I have done gone from the 180 hi flow autozone stat to the 160 stat with the cooling system setup I rec you run when in hot summer temps.
BTW,Now what do you think of elec fans?
Scott
Discussion Starter · #6 · (Edited)
Well Scott you were right.. and your question above is kind of loaded. (Maybe, and probably not intentionally)
I think there are probably some 1000.00+ setup’s with electronic fans that will cool a car like mine effectively. BUT… taking into consideration, aesthetics, functionality, and PRICE….. For 1/3 of that or less I got where I needed to be, and I’m happy with that.
Edit, I’m running a 160 stat without the 2 extra holes…..
Edit again: It should also be noted that when I say flogged I mean multiple sets of tires in one day. Not your average …. Oh, I did a burn out… :) Something’s I expect to last.. Others I don’t.
LOL!!!
Sounds like fun!
Have a great summer cruising with confidence your motors not going to be running hot anymore like it used to with the old cooling system.
Scott
Good stuff!! :thumbsup:
I'll soon be converting to a 4 bolt plate and 4 row core radiator after installing Vintage A/C.
Got most of those items on hand already.
Bill please let me know how that vintage air works out for you, PM me or post here, whatever…. Probably my next mod :)
Omaha, NE to Waverly and back, first car show of 2013 (unfinished, primer class) 80 miles round trip, took her over 100 mph twice... never went above 165 (high was 72 degrees)
2000 Trans Am WS6
hmmm, when I check that link, it comes up at $189.99??
Unfortunately, there are no O'Reilly's in Maryland, or within 100 miles of me. Maybe I'll see about getting one shipped, or just see if Summit can price match it.
Discussion Starter · #15 ·
Maybe you can print this off or screen shot it to help you in your price matching.
(You can also see how the listed specs are completely backwards)
Trust me, I measured it twice :D
2000 Trans Am WS6
I figured out what was happening.
"MY STORE" was listed as "online store", which evidently by default gives the $189.99 price. I entered a random Geogia store as "MY STORE" and the $159 price came up.
Put it in "MY CART" and it stayed at $159, so being that they offer FREE SHIPPING with purchase over $75 or $100 (one or the other), I went ahead and ordered it...:hurray:
Thanks guys! I already have a 4 row Harrison that does pretty good with the other cooling mods, but I'd consider a brand new bolt-in aluminum radiator an upgrade. :thumbsup:
Discussion Starter · #17 ·
That’s awesome Bob, please be advised you will also need the hoses I listed. One more note, the radiator comes with a rubber adaptor (on either the inlet outlet, sorry, can’t remember getting old) just remove it and toss it.. It’s not used in our application. (at least not with a SBC anyway) It will also absolutely not work with a 3 hole top plate.
I’d love to hear how it works out for you. I couldn’t be happier; I can actually DRIVE my car now and watch the road instead of staring at the damn temperature gauge all the time :)
2000 Trans Am WS6
Finally swapped the radiator out....on a big block car it is a direct bolt in with no new hoses or mods needed. :)
Didn't get to drive it due to monsoon like rain here, but I actually can feel more air being drawn through the front of the grill area.
Discussion Starter · #20 ·
That’s awesome! Lots of great information here, I spent about 3 weeks researching all this. Not sure what constitutes a sticky but I hope this will continue to help others :beers:
1 - 20 of 97 Posts
