I have been looking on chevelles.com for a while i have an 87 regal gn clone.here is the the combo what do you guys think.
At sacramento raceway yesterday about 88 degrees out.
used 74 454,781 heads untouched stock valve sizes new valve job,new guides,untouched ports.
8.0 comp ratio
edelbrock rpm manifold,3310 holley jetted 74/84 tall yellow spring(thanks Mr.4 speed)Summit 218/228 cam 500/500 lift,hooker super comps#2455
2 1/2 exhaust h-pipe custom muffler shop bullet mufflers,hei,msd6a,timing at 38 degrees total,mark lv electric fans,3.42 rear end posi,th-2004r gn spec.90/10 ce shocks,no front sway bar.Drove about 240 mile roundtrip 87 octane.Heres the best run of the day.First time out racing
60ft.1.902
1/8 8.242 83.01 mph
et 12.79 @107.1
times varied from a best 12.7-13.2 mph stayed at 105.9-107 lost mph once l lowered my tire pressure is that normal?lowered it to 13 psi et streets.87 octane baby
8.0 comp ratio
60ft.1.902
1/8 8.242 83.01 mph
et 12.79 @107.1
