My 66 keeps burning out both low beam elements, the high beams have not. I'm using westinghouse 4000 new but older lamps. I installed 2 lamps, one lasted about 45 minutes, the other hasn't went yet. I can't solve this one. Carnac
One thing that comes to mind is if your car is overcharging it can blow out lights.
I'd check that first.
Bob (Pa.)
1963 Impala 283
1966 Chevelle SS 409
1969 Malibu 307
1972 Malibu 307
1969 Chevy stepside 350
Check out my website:
Bobs 409 Chevy Page
Chevelle parts for sale
First off, did you check a lamp interchange chart??? What I mean is, are these the correct bulbs? My '70 uses 4001 and 4002, is 4000 correct for your application? If for some reason these are 6 volt bulbs, then we've solved your problems.
If according to the owner's manual, the bulb is correct, then it does sound like we have a voltage problem. You need to take a voltmeter and connect both probes to the headlight plug wires, turn on the lights and engine, and see what kind of voltage your getting. Anything higher than 14.2-14.5 volts is a problem!
Joe
