The only info I find on line is at Chevelle Stuff. That site indicates this was used in LATE '69 with all engines and early '70 Chevelles with L78 only.
The big mystery is the cast and assembly dates..cast June 28 1968 and assembled Sept 20th, 1968 Why would an axle assembled in mid 1968 only be put into use in late '69 to early '70 ?
Also, is this a nodular center section for high hp use ?
Any of you '69-70 experts have any further, better, info on this axle ?
The assembly code is KF, by way of Chevelle Stuff, it indicates 3.55 posi. Which may work behind a TH400, but doesn't seem to fit with a high HP engine and manual trans.
I'll appreciate any enlightenment all y'all can provide...:)
699015
699016
699017
· Banned
its a 3:55 with large ring gear for a 69 chevelle ss the difference in the cast and the assembly date is most likely because of a strike. code chart below
