Iam looking at a 454 locally that i was gonna pick up as i planned on building a 496. The pistons are the same as i have in my current motor ( 2349f ) but the piston is not far in the hole ( less then 10 for sure ) on the flat part .
I couldn't read the numbers on the front pad of the block i could just make out lines but not readable. The heads i hadn't seen yet but were cut at 010. I relize i would not use these pistons or heads but wondered if i would have to have an intake cut if the block was cut .
The guy who has it said it was rebuilt but after the rebuild it was oil fouling plugs on the passenger side and smoking out the exhaust even thou the heads were completly gone thru . I was thinking maybe the intake was sucking oil ?
Iam going back tomm to measure how far the piston is down, drop the pan and check a couple bearings and look at the heads .
