Should I use LocTite on flywheel bolts?
Pressure plate bolts?
Interesting observation. Is it the case that the stresses are by design transmitted in shear in the applications referred to? I would suppose that the fasteners would be tapered or interference fit if that was the case; but I don't know. Who knows?I personally think...
What the proper torque will do in addition to holding the fastener in place is to transfer some of the stress into tensile on the bolt rather than all shear...
Actually the factory used "Star" washers that dug into the flywheel and held the bolt in tension but it's a small point. I guess you could call them lock washers.Factory used lock washers.
