1 - 2 of 2 Posts
yes, after the prop block. If you put the line lock on the back you will lock the back brakes on. I think you are aiming for the front brakes to lock??? right? Line locks aren't for blocking the flow from the master, they are for holding(locking) the pressure in the lines. If so put your line lock on the front brakes then all you do is hit the brakes, hold the button, release the pedal and throw your wallet out the window!!! Smokey burnouts rule!!!
1 - 2 of 2 Posts
