1 - 2 of 2 Posts
I am having a problem with my lights on my 69 Chevelle. After getting it repainted, I am putting the lights back on and now when I put the battery cable back on the parking lights come on and stay on. The tailights do as well. Also, when I turn on my blinkers the left one will work but when I turn on the right one they both blink. I have no idea what to check for the problem, Please Help.
Not seeing offhand why the parking lights are coming on while the headlight switch is off. Think the first thing I would try is to see where the power is coming from. Remove one of the rear tail lights. Measure the two light bulb contacts in the bottom of the socket to a good ground. Do you have 12 volts on the brown tail light wire or 12 volts on the other wire (yellow -left, green- right)? Do this with the turn signal off.
1 - 2 of 2 Posts
