i finally got my console off really hard to get off phew!!!!!! and the conecters are fine wonderind if its the neutral safety switch thats wrong with it
If we are talking about the two lamps that illuminate "P R N D L L1", the neutral safety switch would have nothing to do with it. These lights get their power from the dash light circuit.
Joe
Creator of Team Chevelle's RADIO TECH for original audio questions and answers
70_KiD,
You might be having the same problem I had with the wiring in the consol of my 70. On mine, the wires had become entagled in the shift mechanism and the insulation had worn off of a couple of the wires causing them to ground out and cause a short. I was blowing fuses like crazy before I looked down one night to see sparks flyin under the shift indicator
I simply removed the shift indicator plate, and a little electrical tape and a couple tie wraps later I was back in business
Hope this helps, and good luck!
Joe Scott
70 Chevelle Malibu 350/TH350
White w/black interior
Dreaming of a Big Block!
http://members.aol.com/cantdr1ve55/70chevelle/70chevelle6.jpg
