Will I break bolt bosses at transmission, water pump, and and water neck trying to lift engine this way. Thanks
We usually just lock the tranny in so that it cant move in any direction at all whatsoever.Will I break bolt bosses at transmission, water pump, and and water neck trying to lift engine this way. Thanks
Me too and when I was Young I once had to bend and use my biggest crowbar etc to get the engine up very tight against the cross member with big kickout pan so a bolt snapped and the cherry picker took a jump and put a nice hole in the fiber glass hood 🤣I have used just about every hole avail at one time or another. Intake holes, Head accessory holes, exhaust manifold holes, bell housing holes. Carb plate. what ever works best at that moment.
Think of it this way, A carb plate uses just 4 5/16" studs/bolts... if you can lift it with those, 4 of anything larger will be fine as long as you are not bending, scratching or breaking something in the way.
Well, they say knowledge is expensive. 🤣 There is no better example than the car hobby LOL.Me too and when I was Young I once had to bend and use my biggest crowbar etc to get the engine up very tight against the cross member with big kickout pan so a bolt snapped and the cherry picker took a jump and put a nice hole in the fiber glass hood 🤣
After that I decided to buy a carb lift plate and all I can say is it was worth the money.
