I have a 72 chehvelle original 307 car...now has 468 and 12bolt posi with 4.10 gears...when i put the bigblock in put bb moog springs in the front..for the rear its factory besides a set of lift bars that i had purchased from jegs...raised the rear up a little bit, enough to clear 295/50/15's on a 10in wheel. hooked good with the countless sbc in the car...with hoosier drag radials having a prob with the big block...anyone have any tips on combo's? much appreciated!
The lower control arms that I have let the axle pivot, once u get your angle right. I had to drill holes in the plateand run a bolt threw it. Seems like it raised the rear bout 1/2 to 3/4 of an inch and stiffend it up. I was thinking about **** canning them and get ajustable upper and lower arms. I have a problem with spinning the tires right now...which im running a big block now and more power than its seen with the sbc I have had in it...when i ran small blocks it would set on its ass and hook good...wish I could get an idea of a combo to start with so i don't waste a bunch of money trying different things.
· Vendor
Hello
When you say you had to drill a hole.....What and were did you drill a hole. In the relocation bracket there should have already been a hole machined for the lower control arm. By chance is there any pics that you can post to get a better idea. Sorry for any inconvenience.
Brad :D
