Although racing season has really just started over here, it's time to look ahead and plan next year's engine. I'm planning to build a 565 for the 300 Deluxe over the winter and I'd like your opinions and advice on the combination. Here's the deal:
The car weighs in at ~3520 lbs with me. I have a built Turbo 400 trans (manual v/b, no transbrake) and a 12-bolt with 3.73:1 gear in it (I also have a 4.10:1 gear set). I would like to build a solid roller, pump gas 565 for which I already have a Dart Big M block bored to 4.600" and a Scat 4340 Lightweight 4.250" crank. My goal is to get deeper into the 9's through mufflers and on 93 oct pump gas, with 10.5" slicks. The car sees minimal street duty, so idle quality etc. are not an issue.
In addition to the block and crank, I have a set of Hooker Super Comps w/ 2" primaries that fit very well and I'd like to use if possible. Everything else, including the converter, I'd like your opinion on. TIA.
