If you have a custom dash, i would like to see it. I'm trying to get ideas to plan mine... dimensions and things of that sort.
so lemee see them
1970 Chevelle Malibu, 400sb, Holley 650, Edelbrock Performer, Headers, HEI, PS/PDB, BMR Rear Control arms, 7/8" rear swaybar, CC501's, 1.25" front swaybar, PST Front End, 3.08 open 10bolt, 275/60/15's out back, Corbeau Buckets.... swiss cheese 1/4's :( ... crappy paint.
novel idea... i might just do that.
you do really nice work man.
i was wondering... retaining the stock dash, and taking out the sweep speedo and idiot lights... would it be possible to do this..
on the left, fuel level and fuel pressure ( 2 1/16 gauges) then 3 3/8" Tach and Speedo... then on the right, vaccum, volts, temp and oil pressure (2 1/16")
basically, how big of a plate do i have to work with?
Jutny,
You have an opening approximately 16 3/4" wide and 4" tall on the left and 4 1/4" on the right. Look closely at your speedo and you will notice that there is a slight taper in height. Shrink that by about 1/2" minimum on each end for a border and about 1/4" minimum border on top and bottom. You would have to measure the actual bezel width of the gauges you suggested and see if they fit.
What you suggest sounds like a lot to cram in the area you have to work with. Sketch it out on paper to scale and see what it looks like.
Good luck with the project.
thanks for the info, i appreciate it... i'll do that once it gets warm out again, but i gotta do motor mounts first.
