link deleted
Enjoy!
Enjoy!
Jerry,
The length is virtually the same:
TKO= 24.07"
LGT= 24.05"
If you have a TKO and want to convert, you can keep your driveshaft, speedo cable, isolator mount and reverse light pigtail. Easy swap!
The TKO weighs in at 99 lbs and I do not have the official weigh in for the LGT just yet but it's heavier; I would guess around 115 lbs by picking up the two.
The LGT700/Keisler SS700 will offer more than 15 unique shifter positions and the model shown is a mid-shift for street rod applications. It's also been the red headed step child so to speak and has been put through the wringer; it's undergoing a seize test today and the trans dyno is hummin'!
I should be clearer, How long before production catches up with orders?Thanks for the info. Now ,how long before a fella could order one and have it shipped in a reasonable amount of time, like a week or 2
As everyone knows, we've had quite a mess with the RS600 lead times but that will not be repeated with Legend Gear and Transmission on board.I should be clearer, How long before production catches up with orders?
