Bleeding brakes today as my last requirement before starting - after a 2 year rebuild....and of course some gremlin is in the garage... all started with a bench bled M/C and bled from farthest to closest..... on last wheel.....no fluid coming to caliper.... any recommendations? thanks 71 chevelle...disc front.. drums rear. wildwood calipers and M/C.
Super Moderator
Pull the bleeder out and make sure the hole is clear straight through. Seen them plugged before.
Thank you Levon... I may have it.....popped the prop valve reset and semi slammed the pedal a few times..
