1 - 2 of 2 Posts
MY left blinker doesnt flash (on the Dash)but it works outside. so i figured it was the bulb. But when i found the wire it doesnt have the bulb holder, instead it has a factory clip witch is wired into another harness (that is cut) I cant figure out what this harness is? Could it be for a blinker tach? This is for a 67 with gauges. Thanks for any help.
Yes, the “blinker tach” was included with the U14 gauge cluster option. The dash harness doesn’t have a bulb holder. If you want I can provide you with a pre-made bulb holder with wire and connector that you can install without modifying the dash harness. You may decide to add a tach in the future. The harness and repro tach are available. Although I have heard that the repro tach, for the money isn’t all that good. A factory tach will be high dollar and isn’t real good either. In my opinion nothing looks better in a 67 than a factory blinker tach.
1 - 2 of 2 Posts
