SuperbrightLED's makes a drop-in replacement for the 1157 bulbs we use today. $6.95 each for a 19-LED setup that plugs right in like the regular bulb. AutoZone sells the same ones for twice the price, but still available.
I just replaced mine with these LED's, and like them - when I hit the brakes with only 1 LED installed and the other a regular bulb, the LED went on immediately, then the regular bulb lit. A noticeable time lag before the regular bulb lit (filament must heat before it gives off light - equates to 1/2 second or so, but it was quite distinctive side-by-side).
Flashers won't work with these bulbs until you replace your thermally activated flasher for an electronic flasher (also readily available).
They also make the gauge cluster bulbs. Once replaced, I won't have to go in to change a bulb for 100,000 hours! (Not done with that yet, but the 2 I put in work just as well as the originals)
