Have a 70 chevelle that sit s1/2 in higher on one side.any advice on coil spring clamps? Would rather not use them and pig tail springs cant be cut.
Have you measured all 4 wheels? Often the problem can be at the other end of the car, rear spring not seated correctly or front spring not seated correctly. Coil spring clamps are just a band-aid fix, same for cutting springs to correct issues.
Discussion Starter #3
Discussion Starter #4
Car just had a full 2 yr frame off restoration.all new suspenion parts.shop cant explain why its sitting like it is.ill put it on my lift and check what you suggested about s6prings being properly seated.thank you.
Check to be sure the front springs are seated in the frame properly, not the a-arms. Meaning the coils should be butted up to the stop in the frame spring pocket.
