1 - 12 of 12 Posts
G
My 307 has Leaky Valve Covers. I want to fix them ONCE. Any ideas... double gaskets, gasket goop, heavy metal covers that don't distort????
Cliff
Interesting, I was just going to ask this same thing. I too have a 307.
Use the long spring type reinforcments.Corvairs had this problem these were used the cure it.They are now in chrome most times the problem is overtightening...FRED
After fighting with the silver cork gaskets for a year I finally decided to invest the $12 in a good set of rubber gaskets. So far, no more leaks.
Mark
1970 SS454 LS6 (nom)
"Those who would sacrifice their freedom to achieve a measure of 'safety' deserve neither freedom nor safety."
<BLOCKQUOTE>quote:</font><HR>Originally posted by markcord:
<HR></BLOCKQUOTE>
This is the ONLY solution I've found. FelPro Gaskets are the best in my opinion........
"Laissez Le Bon Temp Rouler' Cha!"
Chevytalk Moderator
GMforums Moderator
"Jungle"Jim
70SS396 & 70 Malibu
My Car
"I don't drive FAST, I just FLY low!"
One of the biggest problems with valve covers is over-tightening the hold down bolts. I do this all the time and finally started using a nut driver to tighten the bolts by hand and this works great.
Yep. Just hit your local parts store (NAPA, Advanced Auto, etc.). They're sure to have 'em.
Mark
I'm using the double thick, laminated (cork/steel/cork) Fel-Pro gaskets. They are reusable. With long spreaders and light torque, I've had zero leaks. This is with stamped aluminum Moroso covers. They are pricey, around $30.
Pat Kelley
66 El Camino, daily driver
67 El Camino, STRIP/street
Pat's Page (CR Calculator, Utilites, car specs)
[This message has been edited by Pat Kelley (edited 06-07-2001).]
Pat Kelly is right. There simply is not a better gasket on the market in my opinion. The one you require is fel pro part number 1641.
1 - 12 of 12 Posts
