Darn, they think they found a leak in the intake manifold.
Would this cause my high water temp problem?
Looks like a lot of "stuff" is going to be pulled off to get the intake sealed.
What other symptoms would I see if the intake is leaking?
Thanks.
Picture: My new motor with a supercharger!
Image: Dyno sheet, 700 hp, 700 ftlb
Picture: My blown 468 Chevelle
Picture: Blown 69 SS Chevelle
Picture: My car on the cover of Super Chevy Magazine
Video: 1 meg video of my Chevelle warming up
Three things can leak from the manifold, oil, vacuum and water. Water will leak outside the engine or into the oil. Your oil will turn milky white. I can't see water leaking from the manifold by itself causing high temps. Of course if enough water leaks your in trouble. Maybe a bad head gasket??
A vacuum leak is going to cause the engine not to run right, ie-idle problems.
You will see the oil leak.
Let us know what they find out.
-Mark
TC# 717
ACES #1641
1967 Chevelle SS396/375
1967 RailVelle(Parting out)
1964 Chevelle 283/195
1975 Corvette 396/425
Rat Garage
1badrat,
Thanks!
I'm guessing it might be a little of both, intake and head gasket.
I saw a little oil on the starter shield when I took it in.
I may not have a cooling problem. I may just be overly concerned. But, there's definately an oil leak some where.
I'm going to go look at it today.
hey tony,
this is just out of curiosity.
What did you do with your old motor. 396 was it? It would go great in a 68 camaro that i'm workin on.
Also, in that vid. clip of the old motor in your car, was that cam THAT big, or was the person sittin in it playin w/ the throttle?
just curious.
-Matt
1971 Malibu 350/TH350 (383/700R4/12bolt in the works)
"It's not how much blood and sweat it took to get there, it's whether or not you have what it takes to finish it."
CAR
ENGINE
