I just put a new cam in a '92 sbc 350. I've got it at TDC #1 cylinder and the lines on the timing gears are lined up. Now the sequence says
as follows:
#1 cyl TDC compression stroke.
Adjust intake valves on 1,2,5, & 7
Adjust exhaust valves on 1,3,4, & 8
Then rotate the crankshaft one turn to the TDC mark, which will put cyl 6 at TDC compression stroke. (#1 will be TDC exhaust stroke)
Adjust intake valves 3,4,6, & 8
Adjust exhaust valves on 2,5,6, & 7
The problem I'm having is the #8 exhaust valve is open on the first sequence. I was told they have to be shut when lashed. True? Any ideas? First cam install.
as follows:
