1 - 12 of 12 Posts
For 1969 the L78 engine came standard with 3.55 ratio, regardless of transmission. Here were the options, also regardless of transmission:
Economy - 3.31.
Performance - 3.73.
Special Order - 4.10.
Dealer Installed - 4.56 and 4.88.
Hope this helps.
Economy - 3.31.
Performance - 3.73.
Hope this helps.
Helps very much!!! Thanks!!! One more question, On my POP it says "C"9DO3 for the transmission. The "C" is for Powerglide--as far as I know that wasn't an option for the L78 but I have seen other errors like this on POP's. Has anyone else? The POP doesn't appear to be a fake and I know that there are very good fakes out there. Shouldn't it be an "X"?
Think C was used for all a/t as I don't see a code showing TH400 for the POP -69-72.
The engine code specified the trans along with the engine.
Check with Dale on that.
The engine code on the POP is T0409KF as you know is 396 375 11.0:01 4BC TH trans. I'm starting to feel a lot better about this but I have been afraid to ask. I'd like to hear from Dale or anyone else. Thanks!
1 - 12 of 12 Posts
