1 - 18 of 18 Posts
michenability
Gareentee its what? I guess if one can make up a word, one can make up the spelling to go along with it. :rolleyes:
Good thing it was like that when he baught it. :sad:
Sounds like a buy if one needs a 4-bolt main block. I'd ask for the machine shop that baked and magnafluxed it for a written report that nothing was found or be ready to have it done again.
Something doesn't jive. L of 70 date is not a '70 production engine. CKQ is not a '70 code....with all the other aforementioned spelling errors (but spelled "magnaflux" correctly... :sad:) it could be a L of 69 block, with a CKO code. Even at that, L of 69 would be awful close to the end of Chevelle L78 production, 12/8/69. It COULD however, be a Nova motor as they used the CKO block as well....
I too was kinda shocked he got "magnafluxed" right. CKO, CKQ, L 5 70, L 5 69, what's a letter or number between friends, right? After all, who's going to check the castings or stampings before layout out $600?
I do show CKO as a 70 L78 w/manual trans and CKQ as a 70 L78 w/manual trans & H.D. clutch but certainly not in December of 1970.
OK, Dale... none of my books show the CKQ code. :)
And even if it was cast December 5th, it would have never got to an assembly plant in time to be used before the Chevelle L78 option was done. Last known L78 was built Dec. 8th.
Colvin's 1970-1975 by the Numbers book, page 57; Peter Sessler's Ultimate American V-8 Engine Book, nastyz28.com's web page at http://www.nastyz28.com/gm-chevy-codes/chevy-engine-codes-suffix-12.php; teufert.net's page at http://www.teufert.net/bbchevy/bbcodes.htm; Catalog of Chevelle Malibu & El Camino ID Numbers 1964-87, page 68; Chevrolet's own Parts & Accessory Catalog under General Information.
Two others I have absolutely no confidence in, one being John Gunnel's Standard Catalog of American Muscle Cars 1960-1972 and Paul Herd's infamous Chevelle SS Restoration Guide, 1964-1972; and chevellebigblock.com's PDF page at http://www.chevellebigblock.com/pdf/BigBlockChevyEngineCodes.pdf.
Maybe they're all (except for the Chevrolet Parts book) just regurgitating bad info, can't say for certain. I will say though that of the 12 1970 L78 cars in my registry, 10 are 4-speeds and all are CKO.
Lifetime Founding Member
I have a reference that shows CKQ as '70 Chevelle AND '70 Nova with L78 and manual trans with HD clutch. Probably from a '70 Nova L78 with HD clutch.
Novas and Camaros still used the L78 later than Chevelles in 1970. Just because it was cancelled in the Chevelle doesn't mean it was cancelled in Novas and Camaros.
Couldn't get the LS6 in those cars remember? And they used the same engine codes in all three - Camaro -Chevelle -Nova
Alrighty then........
That's what I was getting at. It could've possibly been used in a late '69 Camaro as well, since the '69 model year Camaro was extended into early '70 calendar year. Or a '70 Camaro.
Hey Von.
But wouldn't a block dated Dec 5 1970 be for the 71 production year? I bet the owner has something wrong with the listing.
Super Moderator
Levon, on here since 1999 and you haven't noticed it's not ok to post parts for sale offers outside the clssifieds?
I think there is also the possibility that this block was originally a complete engine bought OTC from Chevy in late `70- early `71 and came with the CKQ code as an assembled engine.
I've seen several original stamping CRR and CRV LS6 blocks that were later than the production time frame of 1970.
Good point Rick. Didn't think of that.
Hey Von.
You're right. I mistakenly thought it was a Dec 5, 1969 casting. I went back and looked and it is a Dec 5, 1970 cast block.
1 - 18 of 18 Posts
