1 - 1 of 1 Posts
We put an L.E.D. set of tail lights in a friend's car & have run into a "glitch". With the tail lights on they're great, quite a bit brighter than the original lights. Then we turn off the tail lights & run the turn signal or hit the brake & they're super bright, much brighter than the originals. Then if we turn on the tail lights & run the turn signal or push the brake, you can barely tell the difference as the turn signals flash or the brake lights are pushed they don't get much brighter. They DO flash when required & come on normally, just not much contrast between the tail light & turn signal/brake lights. Since they DO flash, etc. we believe that the turn signal breaker works properly with the lights & I think that the brake lights aren't affected by the turn signal breaker. Anyone have any ideas on how to get that large contrast from tail to brake or turn signals??? Thanks for any help that you can give.
Odie.
1 - 1 of 1 Posts
