Hi all, is there a trick to removing the knobs from the headlight switch and the ring from the ignition switch i have them both loose but cant get them off/out. Thanks Ralph
yes there is a trick!
get your hand behind the dash,locate the HEADLIGHT SWITCH assembly.feel for a push button
(its gonna be hard) if you cant see what im talking about.before you push the (button)
keep the headlight knob in the off position,
push the (button)then "pull out" knob.
(repeat in all "off ,on, parking lights" (locations),untill you find the right way to pull it out.YOU CAN go to your parts store , ask them to show you a HEADLIGHT SWITCH.then you can see the (push button) you need to push :D
While you are there try to get an extra elbow or wrist because you will need them to reach that little button! ;)
BLOOD,SWEAT AND TEARS
I SAY.
BEN THERE , DONE THAT.
YOU WILL CUT,SCRAPE,HURT YOUR BACK,SWEAR,ETC...
JUST TO GET THAT SWITCH OUT.
BUT YOUR CAR IS A LABOR OF LOVE ISN'T IT
