1 - 8 of 8 Posts
ok I just swapped a L6 for a V8 in a friends '63 nova. after getting everything on the starter wont turn. it will with a screwdriver bridging the termanals, but not by the key. the same thing happend to my chevelle a while ago when I did a motor swap.
is this common or am I just missing something obvious?
thanx for your help
Justin
Discussion Starter #3
ive got a brown wire running to the S termanal and the main batttery cable. ive got it to bump once it hasnt since.
Boldly procrastrinating
JWagner has it right, the big purple wire goes on the terminal nearest the block.
Tom
Administrator
The brown wire goes to the R terminal and the other end is hooked to the + terminal of the coil on a points type ignition system. It is to bypass the resistor wire during starting to give more voltage to the ignition.
Philip Valentine
Team Chevelle Member #42 GOLD
[email protected]
Discussion Starter #7
we dont have a purple wire. we have brown and green. I will look to see if one of them is spliced into the purple wire.
thanx
Justin
Administrator
Justin, with the wires disconnected from the solenoid, have someone hold the key in the start position while you use a testlight to see which one is hot, then place that one on the S terminal. It should also be twice as large as the resistor bypass wire.
Philip Valentine
[email protected]
1 - 8 of 8 Posts
