1 - 2 of 2 Posts
I have a '68 Chevelle. The accessories position on my key switch doesn't work i.e. the key will move to the acc. position but none of the accessories will work. Is there a way to test if the problem is in the switch?
Try scratching into the fuse clips on the right side of the fuse block. See if you can measure the ACC power on the fuse clips. Might be easier to look there first instead of on the back of the switch.
1 - 2 of 2 Posts
