Yeah, they moved them out of the 72 assembly manual. It sounds like the flexible switch "fingers" in the column may be bent. The key is supposed to push these together when you insert it. They are below the turn signal switch.
Hey John looks like it might be my repop lock cylinder. Seems like the actuator inside that contacts the switch doesn't always go free when I remove the key. **** me off now I lost the little clip down the column that holds the switch :confused:
