I am replacing the std steering column in a 70 El Camino with a tilt. The tilt column has two less wires on it's harness. It is the same connector, just missing the Key Minder circuit. I don't need the key minder buzzer but I was wondering if not having it connected will cause any other problems....
Anyone ever run into this???
rob
:-D HAH! I used to do that ALL the time, but now I am "programmed" to take the keys out when I get out. I don't know how many times I have been looking all over for my keys only to find them in my HAND!
Thanks for the info.
Rob
When I had my original dash in my '68, my key switch burned up. I couldn't find a replacement for a '68 because it's a unique year. I had to modify a '67 switch, which eliminated the key-minder circuit. I had zero problems with it.
My Web Page (updated 05-22-02)
"Chevellabration Bound!"
Chad Landry
TC Member #643
ACES Member #4556
'68 El Camino, 357, L31 Vortec heads, 700R4, 8.2 10-bolt, 3.55 gears, Auburn Pro Posi.
