We just connected the new engine and light harness from M&H. The Horn relay is new and it buzzes until we disconnect the horn. If we push the horn button the buzzing stops also. Any Ideas on what this could be???
thanks.............bk
I was messing around with my steering wheel last week, and when i hooked it back the horns didn't stop buzzing as well...
I ran outside, disconnected the horns, and went back in..
I found out that the horn wire under the steering wheel was touching the metal..
I had to reassemble it all over again.
What i am trying to say is.. Check if the wire under the steering wheel is thouching in any way metallic parts..
Shai
1972 Chevelle Malibu custom 4dr
Restoration started: February 10th 2001
TC member #1278
Sounds (small joke) like the key minder circuit. Car is acting like you left the key in the ignition. There are contacts by the ignition key tumbler that work when the key is in. This switch, along with the left door switch and relay make up the circuit.
