1 - 8 of 8 Posts
Any issues come to mind?
ive got the 327 about ready to come out of the 53 Chevy Pickup, we have a new Crate GM 350 to put in it.
im mostly worried about the transmission since its a Powerglide from an old checker taxi cab.
were loosing the Generator, and putting in an Alternator so the A/C can be installed out here by the shop Pops knows about. not sure what ill run into doing that, so anything will help!
thanks gang! ill post a thread in Bench Racing when im all done!
· In Memoriam
Is it a new style crate with one piece rear main? That would be a problem, need a different flexplate.
on the 53, anything close to the 327 damper? the 350 damper will likely be much larger.
there is nothing near the Dampner, its pretty far back since it was mounted there after the Straight 6 was taken out and the 327 was put in.
i plan on getting a new flexplate regaurdless, im not sure what you mean other than that, here is the engine that i have to go in it.
the 350 balancer will be fine fitting in the truck,, some crate engines don't come with one..
and the 327 balancer is smaller (little over 6" than "most" 350 balancers (7" or8")
thats all I think he ment, the different balancers don't line you with the timing pointers, as the newer g.m. crates the timing cover is plastic.. with the pointer cast into it..
the flexplate or flywheel (auto or standard) will need to be for a one piece rear main seal.
and make sure the torque converter bolt spacing is correct for whatever is in your tranny(if auto) and 153 or 167 tooth for what ever starter you have..
good luck
this is better
http://paceperformance.com/i-6255330-12499529-gm-performance-sbc-350cid-290hp.html
or really step up
http://paceperformance.com/i-648492...-van-savannahexpress-vans-under-8600-gvw.html
change the last number in the part number to a 3 to get 4 bolt mains
but this gets you a roller cam/vortec heads/one piece seal/ and 350+ hp
but need an electric fuel pump and vortec intake
both are under 2k
Yeah those are nice!
we already have the one i linked in the garage about ready to go, just checked the intake manifold and valvecovers for fit.
· In Memoriam
that one at Summit is a two piece rear main, uses the old style flexplate. looks like it has a fuel pump boss.
1 - 8 of 8 Posts
