Another stupid electrical question. My wiring diagram says there is a 20 guage YELLOW wire that goes to the + side of my coil. Well it SHOULD go to the plus side of my coil but since I don't have a stock ignition it appears to be wired to supply my MSD with a switched 12 volt source. I believe it is supposed to run from the "R" lead on the Solenoid to the + on the coil.
Another wire should go from the + on the coil to the firewall junction. That wire ( on my wiring diagram) is labled 20 W / R / B. The 20 WRB seems to be missing in action and likely was deep sixed by the original owner.
So what is my question you ask? Is the yellow wire which goes from the solenoid the coil + (on a stock system) a switched 12 volt source that can energize my MSD box and my MSD distrib. The MSD has a requirement for switched 12 volt juice to both the distrib and the control box.
Thanks for all your help with this.
Oman
PS Was that 20 W/R/B wire a resistor wire for running after the car has been started on a full 12 volt? I know that the car starts on 12 volts but they run on a lower voltage to save the points. The car is a 72 if that matters.
Oman
