What is the material the factory used between the outer wheelhouse and the quarter panel?
The one I removed is so crystallized and petrified that I can't tell if it came in a can/tube or is a rope type substance.
Here is a pic for reference.
Automotive tire Wood Bumper Automotive exterior Motor vehicle
For some reason the pic is upside down
1969 Grand Prix. 455 TH400 12 bolt.
I think you'd be safe calling it the same seam sealer found on the rest of the body. And to replace it as such. If it were butyl it would probably still have a soft heart.
Well, you could test by putting solvent based wax and grease remover on it. Butyl would dissolve, seam sealer would not. And you'll probably use modern "NVH foam" there anyway. A plain daub of urethane seam sealer would be good enough to provide that support for the quarter though. Whats there could have yes been a molded gob of some other sort of pucky, theres no telling. Imagine the funky tip of a seam sealer gun in a muscle era GM factory at the end of a shift. It probably made shapes like the PlaDoh Fun Machine.:LOL:
