Is this intake any good for horsepower?
7493 Views 2 Replies 3 Participants Last post by  Shawnbaxter288
It's a GM aluminum intake casting number 14101074.
Also does it fit Vortecs? I was told it did but am not sure...
Not a Vortec intake. :noway:
Common 1980's aluminum small block smog intake, usually found on 305 motors, for a Q-jet and fitted with an EGR.
No big deal...
BTW, Vortec intakes are very easy to identify. They only require 8 bolts, two on each corner, none along the mid section of the flange, and the bolt holes are not angled like most other SB intakes. Drilled straight down vertically.
I have the 14101074 on a vortec motor with the bolts that are in the middle of valve covers.
