1 - 20 of 231 Posts
Is it possible to have a firewall tag which indicates 1966, on a 1967 Chevelle?
See picture.....
Motor vehicle Light Line Font Gas
Rivets look good can you send the pic of the front end of the car...maybe a mistake in stamping...
very interesting...
From my seat it doesn't look good,... look around the body for the other VIN #'s that were stamped into the sheet metal, a search here will tell you where they were originally located.
There's vin numbers other than the door jamb vin plate? (Still a newbie)
What is that document in post number 4?
Yes there is a partial vin on the frame and on the firewall
Super Moderator
My 68 has a partial vin # on the rear driver side top frame and on the firewall behind the AC box. I also have it stamped on the topside drivers side rocker panel. It's not showing 138 so the previous owner didn't try to pass it off as a SS but the wrong year on the trim tag. I will leave that to the 66 and 67 experts here.
The vin indicates the car was built in September of 1966. That trim tag is an August of 1966. I highly doubt the trim tag belongs to that car.
Reactions: Kirk's67SS
PARTIAL VIN...may be located on the top of the frame rail on the drivers side...hard to read, and possibly on the firewall behind the heater box...nobody said this was going to be easy...GOOD LUCK
Discussion Starter · #16 ·
So the body and the ac box have to be removed to see these VINs?
Super Moderator
You can probably get a small dental type mirror between the frame and the body. My 68 is about a foot or so from the end of the frame. Maybe two feet
Discussion Starter · #20 ·
There's nothing on frame that's readable, since entire car is undercoated....no number near blower motor, non near the wiper arm.....
Not concerned, as I'm not into numbers matching, history etc....just curious about the trim tag....
1 - 20 of 231 Posts
