I think I saw someone else ask this but can't find the ansewer, I would like to go with a better fan setup on my 65 elky is there a later model fan shroud from the salvage yard that works on these models? Thanks.
the 68-72 a body shroud is too big. I have that yr fan but the shroud was bigger than the radiator if I remember. Right now I don't have a shroud which makes it scary when checking the timing. So I'm going to go to the junkyard and pull an electric fan. Only problem with this, is they draw a lot of power and you will have to convert to a newer alternator.
How bout a Repro '66 chevelle fan shroud?
