Whats your intake,carb,exhaust and just as important your expectations or type driveing you expect to use the car the motor will be used in?
In general that cam is small/mild for a 496 esp with 373 gear but if mild is what you want then that cam is mild & what you want. But that cam maybe too mild on int dur which could cause too high cylender pressure resulting in detonaton so keep that in mind as a question to ask the cam mfg.
Call Harold @ Lunati cams (Check website for tech #),he will definately get you the exact cam your looking for after you tell him your eexpectations for your ride.
Scott
