I am in the process of installing a new msd streetfire. I bought the advance kit and as it stands I am going to install the light springs along with the weights from the kit(pn,msd-8428). This should give me 24* of mechanical advance at 30000 rpms, along with 12* initial my total should end up right around 36* @30000 rpms.
So the question is, will 12* of initial be enough? My cam specs are .474/.498 amount of lift, and the duration @.50 is 214/220. Motor is a 383 with dart pro 1 heads. I see most people like to run 14-16* degrees on their initial......
Brian........
Brian........
