R
Rick Morder
·Guest
Help, I've got an all stock 72 350 4bbl(q-jet), the darn thing has developed what at times seems to be a fatal miss (back fires out the exhaust), runs extremely rough, and sometimes dies. It will fire back up, clean itself out and run semi ok (if I drive easy),
I've gone thru the electricals, carburation,
fuel pump(6psi), vacuum (steady @ 15"), compression (150 psi). Now the interesting note: once while testing the compression on #5 cyl the pressure rapidly self relieved, I have a Sun compression tester with a vent switch and usually have to vent every cyl after checking, I've tried to get it to do it again but no luck, also the spark plug #5 has fouled on 2 occasions (all the others are fine), any thought on bent valve or worn springs, ps. the motor has 96000 orig miles and never been apart. Thanks
