Trouble with these old rides, cant hook up a code reader! From Bad gas to, ancient wiring, to a faulty ground strap, you have to start checking boxes off systematically. I would have guessed ignition wires, frankly. PS I measure the resistance of every wire I touch, as I've busted a few during install. They are delicate. I miss solid core wires.
So when you check spark, it is blue or yellow? Yellow = weak = coil. Coils usually fail 100%, but sometimes.....
[/QUOTE
This morning, I am working on making sure the timing is correct. No crossed wires ,etcI agree with this. Chase the cruise problem first. Sounds like a lean miss.
OP should state his idle and total timing specs (I dont see this anywhere), and how much vac adv is being added.
Also previously asked but not answered,, what kind of carb?
Also does he have an AFR meter?
